MODELING A TIMING BELT
  • Thread starter Thread starter jacksoss
  • Start date Start date
J
jacksoss
Guest
HOW DO I ADD TEETH TO A VARIBLE BELT SWEEP
you can create one teeth and use command and create pattern using pattern along curve option
I could not get it using a curve pattern. I instead tried the old method of patterning the points and then reference patterning the protrusions. Picture is as below.
Thanks, I cound not get it using curve pattern.
Jack
SRINIVASANIYER1,
Could you, please, send me the ProE file of belt patterning the protrusions.
Thank you so much
Edited by: poldy
I uploaded a zip file.
2012-02-09_224722_timing_belt_trial_zip.prt.zip
Please note: The model only elucidates the methodology and is not modeling an actual timing belt. Users are requested to change the profile and the Length according to their requirement.
Users are encouraged to view this video for more details
[url]http://www.google.co.in/url?sa=t&rct=j&q=youtube%20l ink%20chain%20sciyer&source=web&cd=1&ved=0CCMQtw IwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Di5t4 xSk06_w&ei=cpI0T8SSIIfJrAf6oPG5Dw&usg=AFQjCNERmjnXY3 Gc_nkJjFzOQdtKI3dZPw[/url]
Thank you Srini.
But I believe the Zip file is empty or corrupted
Edited by: poldy
