Jacob Cheverie
Aerospace
I have attached a very crude drawing of a simple part. There are two datum planes (A and D) and two datum cylinders (B and C). Let's assume that I wish to assign a positional tolerance on datum C, with datum references A and B (applied at MMB). The question is this: What is the size of the MMB of datum B?
Now, the MMB size will equal the MMC size if there is no geometric tolerance assigned to B. Y14.5 states that, if there is a geometric tolerance assigned to B with respect to the preceding datum structure (in this case, A), then the MMB size will be equal to the MMC size of datum feature B plus the allowed geometric tolerance on B with respect to datum feature A. In this case, it would be MMC size plus .005.
Here's where I'd like some feedback - If, contrary to the dimensioning style of ASME, datum feature B were to have a positional tolerance with respect to datum feature D (and no tolerance w.r.t. A), could some proportion of the geometric tolerance be used to increase the MMB size of datum feature B? The proportion would certainly depend on the perpendicularity between datum features D and A. As the two datum features depart from perfect perpendicularity, less of the positional tolerance zone (1.25 from D) can be used to shift datum B toward, or away from, datum C.
My question ultimately comes down to: How rigid is the requirement that the boundary increasing tolerance be related to datums of higher precedence, exclusively speaking?
