Missing Draft Entities from Drafting
  • Thread starter Thread starter Aditya Soni
  • Start date Start date
A
Aditya Soni
Guest
Greetings, this is the first time for me on this forum. Needed your help for an issue...
I'm having issues while editing the Drawing that I made in Drafting in Creo 3.0. I cannot select the sketch Lines & Circles as I used to do early...
Here While in the Layout Tab, I can see layouts..
Here in the tables tab, I can select and view tables...
But,
In the sketches tab, It's again Layout.
I remember there used to be Draft Entities like this...
But now there is no way to select the line and circle forming the First angle Logo...
I hope this much data is sufficient to make you guys understand my problem...
The entities you mention you would like to select probably reside on the .frm
If you are trying to edit it while it is included in a .drw, you will not be able to.
Normally, to do some selecting, one would hold the alt key down.
