T
trickepat
Guest
Hello, first timer poster here.
Solidworks 2011. I am trying to mirror an extruded cut that goes up to a surface which is not on the mirrored side. This causes the mirorred cut to cut completely through until it reaches the surface on the original side.
When I try to just mirror the geometry, solidworks tells me that that isn't possible.
I tried to create a plane where the mirrored surface should be but I have no real idea how exactly to do that. I suppose I could find the start point of the surface and then measure the angle, but I will probably be making changes to this model and may not remember that I have to manually change it.
There has got to be a better way! Anyone have any suggestions?
