Mirroring a Pattern
  • Thread starter Thread starter Axel
  • Start date Start date
A
Axel
Guest
I have created a hole pattern array and I am trying to mirror, but when I select the pattern the mirror button will not highlight.
Any suggestions.
Any suggestions.
You can try to mirror the pattern hole with the following procedure:
under the menu "Edit" select the option "Operation with the features" (or something like this, I'm Italian, and I have Pro-E with Italian lenguage), select Copy --> Mirror --> Select--> Indipendent --> Done ----> select the object --> plane (or crate a new referiment) -->Done.
I hope that all is clear!!
Bye
MRPX
Go to Edit>>Feature Operations>>Copy>>Mirror/Dependent. Then, select the pattern, and finally the mirror plane.
