Hello skilled designers. I wonder if you would understand why this hollowed part works fine, but when I mirror it, the second instance is solid. I'm looking to create a 1/4 section & then radially pattern it. I'm including the solidworks file below.
Thank you in advance for your advice.
Thank you. I tried both methods. I first attempted to mirror the whole body, and then just features. Neither worked, but after some rebuilds, I was able to get the part to mirror as a hollow segment today.
