Mirror part
  • Thread starter Thread starter gallioncd
  • Start date Start date
G
gallioncd
Guest
Ok, I have a CUSTOM structural member, that I have added holes and cut extrusions to. I need to make a left side version of the same part. However when I start a new part and I go to INSERT the mirror part option is grayed out. Did I do something wrong or is there another way to do this without having to redo all the work for the left side?
Thanks.
select plan to mirror part
Thanks.
If you are in a part file try to "select a plane" and then insert "mirror part".
If you are in an assembly file, try with "mirror component" (under linear component).
