METRIC CONVERSION
  • Thread starter Thread starter cpthomp
  • Start date Start date
C
cpthomp
Guest
CAN ANY ONE TELL ME HOW TO SHOW BOTH METRIC AND STANDARD UNITS ON A PRINT?
CUSTOMER SENT METRIC PRINTS AND I NEED TO CONVERT TO STANDARD UNITS FOR THE SHOP.
In your drawing.dtl file, there are some settings that you can use for dual dimensioning:
Dual_Dimension_Brackets (shows secondary dim in brkts)
Dual_Dimensioning (on or off)
Dual_Secondary_units (which unit to be secondary)
Just start typing the commands I listed above in the Options box and they will come up. To make viewing easier, set your sort to By Category. Good Luck!!
THANKS IT WORK . NOW I DON'T HAVE TO CONVERT IT MANUALY.
