John Downing
- Sep 7, 2021
- 2
I am designing a solar carport that utilizes the PV panels as the roof surface. The concept is simple: 4 square posts with aluminum I-beams connecting the easternmost and westernmost pairs, and aluminum C-channel joists spanning between the I-beams. The frame is the mounting grid for the panels.
Other structures I have seen with similar framing members have an angle piece to join the joists to the I-beam. Some are welded, some are bolted. I intend to bolt mine.
Q1) What are these angle pieces called? I have searched several suppliers for aluminum brackets/cleats/angles/whatever and not found any over 3" x 3" x 3"; I'd like to use 6" x 4" x 4". I suppose I could simply buy some aluminum angle stock, cut to length, then drill my own holes.....
Q2) To get the top of the joists flush with the top of the I-beams, is it standard practice to cut back the top flange of the joist so that the web can be moved in closer to the web of the I-beam? Joists will be smaller than the I-beams so the bottom does not need this alteration.
Q3) I have found only aluminum C channel that looks like half of an I-beam, like this: [
I would like to find aluminum joists shaped more like a square tube with 2/3 of one side cut away, like adding serifs to the [ example above. I have seen steel joists formed that way but not aluminum. Is there a specific search term I should use to find such an item?
Q4) To attach the I-beams to the posts, I plan to cut the top and bottom flanges of the I-beams flush with the web of the I-beam, just enough to clear the post, and bolt the I-beam directly to the post. The other side of the flange would be unaffected. Is there any significant loss of strength in the I-beam when the flange is cut out at the end on one side?
Thanks!
Thanks!
