A
AngusW
Guest
Hello all,
Im very new to ProE and i am experiencing a multitude of problems. I want to design a blade thats material properies vary with distance. The model itself is built as a solitary part with complex geometry.
I tried breaking the part up into numerous sections and reassembling it with a material property per section. however when i run the model in Pro E i get an error stating that the "highligted solid element has singular mapping"
To overcome this issue i tried redefining the mesh using brick wedge and tetra shapes and increasing the number of nodes. Unfortunately this results in the program crashing and no error's are identified. Is there any way to overcome this issue? Is there any easier way to assign different materials to sections of the same part?
Thanks a million,
Angus
Thanks a million,
Angus
