Meshing a surface
  • Thread starter Thread starter ZAFAE
  • Start date Start date
Z
ZAFAE
Guest
Hej every body, I have one question for you
Does any body know any kind of external meshing program that could be used in a CATIA surface model?
And if so, is it better than the one we have in CATIA V15?
Thanks guys
Based on your previous post, I'm not sure if I understand what you're doing.
Could you please define "meshing"
Which CATIA workbench are you currently using to create the "mesh", and what are the problems you're finding?
thanks
Meshing
Hello:
Well im working on a surface model anb I need to mesh this model in order to obtain and export the coordinates of the meshed model to analyze the model.
the mesh element that I need to use is a qudrangular element.
I hope that this explains a litle bit more what I need with an external messher.
thank you for your time
ZAFAE
