UTK_Civil
- Oct 23, 2019
- 4
My facility has numerous cast metal treads from the 1950s. These treads are starting to fail some with large cracks and some with small cracks. I recently started having a 1/4" aluminum plate added to the treads with small cracks...say less than 2". I have the crack stop drilled and add the plate on top of the existing tread with a bolt extending through both the 1/4" skin, the original tread and angle supports located at each edge of the tread. I recently was questioned on this method as the person was concerned that the 1/4" plate would not hold if the cast tread underneath failed catastrophically. Does anyone have any experience with this type of situation?
