mechanism to .avi
  • Thread starter Thread starter Richy
  • Start date Start date
R
Richy
Guest
How can i create an .avi file of a mechanism in action?
i've been using camtasia recorder (free download) for creating avi's of EVERYTHING. whatever happens on the screen gets recorded.
Is there find replace option in table?
huh?
Once you have set up and run the mechanism motion definition or ananlysis (depending on which build of pro/E you are using) you can use RESULTS, PLAYBACK, and once you have the player on the screen, you will see a capture button which takes you to the avi creator
but the quality of video output is very poor, a mechanism setting of 15 secs is giving me a video file which runs for less than a second.
Guru
but the quality of video output is very poor, a mechanism setting of 15 secs is giving me a video file which runs for less than a second. is it possible to improve quality in any way.
Guru
Does the the entire 15second run go very fast or is it only a small part of the motion that runs?
Its only a small part of the motion running.
Guru
increase the frame rate to 24 .......... currently ya should be using the default value of 10 .....ya mite neeed a higher end machine fa this
