P
phwarren
Guest
Hello:
I have a mechanism model with a slider going left and right on a rail. I have a shock absorber on either side that is also modeled with mechanism. Here is a picture:
How do I set this up in mechanism that when the slider hits the cushion of the shock absorber it pushes the shock in until the shock piston stops (already set in the shock joint axis settings)?? Currently, the slide goes right through the shock piston as in this image:
Thanks in advance for the help.
Edited by: phwarren
Edited by: phwarren
