Is there any way to tell it that it can't go through another body?
Using your help, I got the limits set on the first linkage, but can't seem to get it to work on the second, because as the first linkage pivots around, the angle is different on the second.
Maybe if I explain a little better it would help. What I have is basicly a T made of two linkages(pinned) The bottom of the T is pinned to a mount on a beam, one side of the top part of the T is pinned to a hydraulic cylinder. In the real world, there are certain physical constraints, the linkage can not swing back around and go through the cylinder, or the beam, or etc. I set the angle limits on the vertical part of the T, and that part works fine, but having problems setting the cylinder, and the top part of the T.
