R
Raychar
Guest
Hello everyone!
The attached pictures show the a cover is opening, its hinge surface touchs on
a slidingblock which is allowed to be moved vertically:
1) Picture 0 shows, the construction, Picture 1 shows sliding blocksurface A touchs with hinge surface B.
2) Picture 2 to Picture3 showssurface Agoes to middle andend position of surface B (By usingthe cam/follower method, Mechanism is ok)
3) When the cover continues to rotate counter-clockwise direction, in picture 3, surface C of hinge which will take up the job ofsurface B will press on surface A andthe sliding block will be moved further downward.During thismoment, surface B will seperate fromA.
Can anyone have an idea how to figure outthe mechanism of above item 3)which progressively takes transition for the cam surface A goes from surface B to C.
Thanks in advance for the helping.
Raychar
Picture '0'
Picture '1'
Picture '2'
Picture '3'
Raychar
Picture '0'
Picture '1'
Picture '2'
Picture '3'
