R
r1kkie
Guest
Hi!
New here so hopefully I posted in the correct section.
Im trying to make adjustable wrench, the problem I have is to attach the screw and the clamp(?) so when you rotate the screw the clamp is moved back and forth.
I have connected the screw with a pin and the clamp as a slider. But how do I connect them to work together?
Excuse my English, not sure what words to use, hope you understand my problem.
Thank you!
Thank you!
