Mechanism Dynamics?
  • Thread starter Thread starter proed
  • Start date Start date
P
proed
Guest
Does anyone have some pointers on using Mechanism Dynamics with Pro/E assemblies?
We have the licenses, and I've seend some of what this can do. I'd like to start learning a bit more about it.
For starters - how do you activate it? or do you need to install extra software?
Ed
Unfortunately, I don't know of any tutorials for it. KinetiVision is in the process of doing some videos, but I don't know when they will be done.
You have to have the MDO module. MDX is the basic Mechanism Design Extension. MDO is Mechanism Design Option, which gives you forces, kinematics, & dynamics. If you have MDO, enter Mechanism Design and the extra pics should already be there.
Also you can find a simple tutorial to get started with MDO in your hard disk :
C:\Ptc\proe2001\demos\demo\mdx\tutorial3
try for it
Hello ProEd,
If you have access to the two proE help cds on of them is called Advanced Help Topics and it containts pdf files with some tutorials. I remember see the mechanism tutotrial in the advance assembly pdf file. Hope this Helps!
Luis
