C
coseng
Guest
I have a model of a motorcycle engine and chassis with all the joints defined and am having problems getting the assembly to drag properly. When I pick the swingarm or front wheel or crankshaft to drag, the part moves freely in 3D space as if there were no constraints on it. If I suppress the engine from the main assembly the chassis then drags properly and the engine drags properly when opened in it's own window but when fully assembled nothing drags properly. When going into mechanism mode the ground body does not include the parts that should be listed. All of the assembly constraints are constructed properly. I a
m using WF3 M100 and am at the end of my sanity trying to figure this out.
Chris
Chris
