Mechanism design
  • Thread starter Thread starter c.mpoutsioukis
  • Start date Start date
C
c.mpoutsioukis
Guest
HI!!!!!!
How is it possible when a part is moving, as a result of a motor, to stop when it encounters another part????
You could replace you servo motor with a forceand then, depending on the geometry and the nature of relative motion, you can:
-create cam connection between the parts with lift-off enabled, or
-create joint with limits.
Make sure you specify a restitution coefficient equal to 0 for the cam/ joint with limits. That means the impact is perfectly plastic so the first part will rest on the second one.
Thanks a lot!!!!!
