May 22, 2007 #1 A Amando Guest I want to get the length of the sweep which I have drawn on a spring using a sweep. Thanks in advance.
May 29, 2007 Thread starter #2 A Algernon Guest Hi, You can use "Measure Distance" tool to measure the length of the path you used in sweeping. Go to Tools>>Measure Distance and pick the path.
