to boot... make sure you keep the 70 percent rule on the base of your ribs. i.e. 70 percent of the material thickness. Another suggestion I give in plastics workshops is to use a parameter for the material thickness (shell) so your nominal rib thickness is always 69 percent of the shell thickness.
In most cases where a sink mark occurs is where 12 of 13 ribs were modified after changing the shell thickness. the 13th rib gives and unflattering sing mark.
