Maximizing Wildfire at startup
  • Thread starter Thread starter dans
  • Start date Start date
D
dans
Guest
Can anyone tell me how to maximizethe Proe Wildfire Window at startup.
Thank You
In Wildfire 2.0, config.pro use.
open_window_maximized Yes
Thank you very much "robertib" I could not find that even in the find command in the config.pro options.
Thank again.
Think I found this at proe.com. Hope it helps.
Sam
Maximising the Wildfire Window on Startup
By Edwin Muirhead, CADmin
Wildfire uses a lot fewer righthand menus than older versions, leaving
more screen area available for modelling. For this reason, you may like
to start up Pro/E with a maximised screen. Windows startup settings and
Pro/E menu/window settings have no way to maximise the screen, but you
can do it using a trail file:
Copy this text into a text editor & store in your Pro/E startup folder as max.txt:
!trail file version No. 1255
!Pro/ENGINEER TM Wildfire
~ Activate `main_dlg_cur` `main_dlg_cur`
~ Resize `main_dlg_cur` `main_dlg_cur` \
4 -0.109482 -0.109482 35.034213 26.740958
~ Move `main_dlg_cur` `main_dlg_cur` \
2 -0.109482 -0.109482
< 0 1.000000
Edit the Pro/E shortcut file with the trail file as an argument appended to the target, eg:
"C:\Program Files\proeWildfire 2.0\bin\proe.exe" max.txt
Note: This particular text file works on my system - you may need to tweak it for yours... or just
make your own:
1 - Start Wildfire as normal
2 - Maximise the window
3 - Exit Pro/E
4 - Edit the trail.txt.1 file: remove the Exit / Close commands and save as max.txt
It worked fine... thanx robertib
robertib
Thanks for letting us know about that solution. I wrote the article mentioned, and this new config option is definitely an easier way!
Ed
Dans.........
thank you, thank you thank you!!!
