abusementpark
- Dec 23, 2007
- 1,086
Have y'all come up with any good rules of thumb for the wall maximum opening width in anchored brick veneer before a loose lintel is required? They are commonly provided for door widths as narrow as 32 inches. However, it can be questionable for things like small mechanical louvers (say 16" wide) or scuppers (24" wide).
Also - what is the maximum width that you use for a horizontal leg on a loose lintel? I have been telling architects 4" maximum and that is causing some coordination issues with newer energy codes. If they want a horizontal leg wider than 4 inches, we switch to a WT lintel.
