material assignment
  • Thread starter Thread starter kiran1810
  • Start date Start date
K
kiran1810
Guest
hallo all,
Is it possible to assigndifferent materials for different features in the same *.prt ??
I hope many of u will find this question absurd, but still I would like to know if it is possible or if there is any other way that I can do the same....
I am trying to model/analysis a tennis racquet. I have to assign different materials to the frame and the strings. How can i proceed?
regards,
satya.
It sounds like you are constructing your model as a *.prt. If that is the case, I would suggest constructing your model as a *.asm. This will allow you to assign different material data to the respective individual parts.
if you are intersted in composites then use pro/composites.
Israr
firstly, thnx for the options u ppl hav provided.
Robertib: the link tht u provided seemed as, if I require to assign diffferent materials to different instances of the same part but not atthe sametime which unfortunately is my requirement.
chrisvoges: ur option is the way which I have been trying for some time..may be it works out for me... still goin on with the process....
Israr: can u open up more information on the option that u hav provided... i cud not follow what u meant.
regards,
satya
