MASS PROP ANALYZE
  • Thread starter Thread starter vetrivel
  • Start date Start date
V
vetrivel
Guest
hello,
i am working with pro/E,,in this the mass properties analyze results value are in tonnes...how can i getthose results in kilograms
thanks....
You need to go to top drop down toolbar 'edit' then choose 'setup' then pick units from right hand toolbar, and change your units from mmns to mmks or alternatively make a custom set of units. Note be careful when picking the method of converting units!
use customized start part and start assembly such that you dont need to change setup everytime.
Israr
hello vetrivel!
Its very simple man!
just follow the steps,
1.Go to EDIT menu,
2.Go toSET UP
3.Go toUNITS
4.Change the units as per your requirement
Thats it & done!
