This is possible but not very elegant.
Create a mapkey to save as "tif" (Used for filename only. You may want to choose other type)
call a batch file to get filename and write to config.pro
load the config.pro
call another mapkey to open drawing
Note: The second mapkey (ii) will get duplicated in the config.pro.
Suggest you backup the config.pro before starting any work.
Restore config.pro after finishing with proe.
Worked ok in proe2001
my default proe directory is c:\temp
Change any lines with this in to your default proe directory
Add the mapkeys od and ii to c:\temp\config.pro
mapkey od @MAPKEY_NAMEopen drawing;@MAPKEY_LABELopen drawing;\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `File`;\
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\
mapkey(continued) ~ Activate `main_dlg_cur` `File.psh_save_as`;\
mapkey(continued) ~ Open `file_saveas` `type_option`;~ Close `file_saveas` `type_option`;\
mapkey(continued) ~ Select `file_saveas` `type_option`1 `db_563`;\
mapkey(continued) ~ Activate `file_saveas` `OK`;~ Activate `shd_img_param` `OK`;\
mapkey(continued) @SYSTEMstart c:\\temp\\drwopen.bat;\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `Utilities`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Utilities.psh_util_pref`;\
mapkey(continued) ~ FocusOut `preferences` `InputOpt`;~ Activate `preferences` `Open`;\
mapkey(continued) ~ Activate `file_open` `Open`;~ Activate `preferences` `ok`;%ii;
mapkey ii ~ Activate `main_dlg_cur` `ProCmdModelOpen.file`;\
mapkey(continued) ~ Activate `file_open` `Inputname` `yourdrawingname.drw`;\
c:\temp\drwopen.bat
(copy lines between *****)
@echo off
pen proe drawing from prt or asm
for %%F in (*.tif) do set picname=%%F
set drwname=%picname:.tif=.drw%
del %picname%
>>c:\proe_temp\config.pro echo mapkey ii ~ Activate `main_dlg_cur` `ProCmdModelOpen.file`;\
>>c:\proe_temp\config.pro echo mapkey(continued) ~ Activate `file_open` `Inputname` `%drwname%`;\
>>c:\proe_temp\config.pro echo mapkey(continued) ~ Activate `file_open` `Open`;
exit
