S
smores
Guest
Short version - I need a mapkey that can change the drawing scale (not detail scale -the drawing scale in the bottom left corner).
Long version - making a mapkey to automatically generate sheet metal flats. 98% there - but the only way I can set scale is to change the view scale - which leaves a note, which messed up my manufacturing group. I can have notes inside the perimeter of the part, but not outside. So that note has to go.
When I record changing the scale - it doesn't take - I've tried it several different ways.
I cannot find anybody else withthis problem- which tells me I'm doing something either wrong or stupid (or both). I'd appreciate some enlightenment.
Edited by: smores
Edited by: smores
