S
SVPJ
Guest
1) I want to create a mapy key so that in assembly it will open a perticular part which contain "XYZ" word in its name & measure the shortest distance between first & last datum point of that part. Is it possible? What will be the code of map key?
2) When I measure distance between two datum points using ANALYSIS-MEASURE-DISTANCE it is showing distance only in metric. I want it in dual unit mm & inch. What setting I need to change for this dual unit?
I am using proe wildfire 3 & wildfire 5.
Thanks for your help in advance.
