Thank you pmarc for your comprehensive review.
You improved my understanding of this geometrical callout (which is not very popular / used in my world, but I need to know it nevertheless).
One interesting fact about form controls in general, from four of them (circularity, flatness, cylindricity, straightness) at least three have issues/inaccuracies with/within their definitions. Isn’t it strange?
Circularity: the axis which is intended to be used is not clearly defined. More decisive axis could be indicated. “any plane perpendicular to an axis or spine…..” Wouldn’t you want something more precise? Or maybe even no axis needed at all, in the same way as flatness is defined.
Cylindricity: “all points of the surface are equidistant from a common axis”. As discussed before on this forum, maybe that common axis is not needed and only two coaxial cylinders suffice.
Surface Straightness: from 1994 to 2009; nominal axis replaced with the axis of UAME, which, probably, is a good move to clarify things.
DMLS: as discussed above.
So, to recap, 75% of the form geometrical callouts have issues (only flatness is spared from this infamous and unfortunate group).
