Make quick simple drawings?
  • Thread starter Thread starter Fred_The_Frog
  • Start date Start date
F
Fred_The_Frog
Guest
I have made a model with about 63 parts, and I need to draw
and dimension all of the parts for my school engineering
project. Is there any way i can get Pro Engineer to do the
drawings for me, so like make a drawing with an
orthographic view and just some simple measurements and
save them, or do I have to go through each part and do it
manually?
You could create a drawing template that can add views and show model dimensions. If you need to add created dimensions you need to do those manually. It's probably not going to do everything but that probably depends on what you want to show.
you can create a batch file with the commands to create a drawing with views you need, turn dimensions on and notes etc. then put the part files in the batch file and run it. It will take some time setting it up though.
Gary
