K
kiwinige
Guest
Our drawing format is set to use the field &dwg_name which is the name of the file.
In our case this is set by ProductPoint.
Some of the other fields in the drawing format use parameters and data from the part model.
Is it possible to feed the drawing parameter back to the part?
In this case I want to feed the parameter dwg_name back to the part.
Edited by: kiwinige
Edited by: kiwinige
