MACRO: Save management, rename files
spe88
Automotive
Jul 17, 2016
17
I know there is existing a macro what I needd, because I used it once in VW nTool environment.
So I need a macro where all the files in the structure can be saved to a location with its actual name which coming from the data what found its Product tab of the CATIA file.
If I rename the part number and/or nomenclature it should have change the file name too.
Thank you
