Macro Location
John Jr
13
I created a macro and it saved it to my Model file. How do I change the location or library to which the Macro saves to?
At the record macro GUI window, the first field is location.
Choose "Macro Libraries" and select directories for type and then add a folder location or choose existing.
If you have a macro that is in a .catpart, open that file and select that macro to edit, then you can do a save as to another location outside of your catpart.
