LWN with appendix 2 MAP lower than MAWP
Ehiman1
59
Dear gents,
I have to check a long welding neck 2” #300 with corrosion allowance (3 mm) and external loads with ASME appendix 2, but doing so I found that MAP is lower than MAWP.
The required thickness is 20.3 mm and with LWN standard we have 20.7 mm.
I don’t understand how it is possible that MAP is lower than MAWP, someone could help me please?
Ehiman1, B16.5 flanges are known to often fail Apx 2 calculations due to the different methodologies.
You'll have to find another route.
Mike
Why are you doing this? Use it because of the corrosion allowance or the external loads? How are you handling the external loads with Appendix 2?
It is a client’s request when corrosion allowance is on the flange. I added an axial load and bending moment and calculated an equivalent pressure. Ah the same time they want I verify the rating and thickness of the flange against corrosion allowance
Ehiman1
Try with hand calculations.
It is very unusual that corrosion be applied to the flange thickness.
Use UG-44(b) for the external loads and ignore the corrosion allowance. The use of Appendix 2 on standard flanges is inappropriate. That is not the purpose of Appendix 2.
