XR250
- Jan 30, 2013
- 6,134
Have a client who wants to add a second story to a house AND raise the ceiling 12". The contractor is proposing the detail shown. The LVL would act as a distribution member so I can support the second story loads down to specifically reinforced points in the existing craptacular foundation. it would also serve to provide the needed 12". Boise does not list any numbers for cross grain bending but they did say 20 psi is OK for direct tension perp to the grain. If I assume I can nail the plys together to achieve composite action, the section modulus is 3.5X3.5/6/12 = 24.5 in^3
The flexural tension would then be 75 x 15"+/- moment arm/24.5 = 46 psi. Higher than 20 psi but does not seem unreasonable. One other idea I had was to use a single 24" LVL and sheath both faces in 3/4" plywood which has the availability for tension. Achieving composite action would be required here as well.
Does anyone have any other ideas?
