sofia-safi
Student
- May 3, 2025
- 7
Hello everyone,
I’ve been searching for quite some time for the traditional method of designing a centrifugal pump impeller — the one based on manual hydraulic calculations, not the modern CFD/CFX-based approach that starts with a meridional surface.
I’m specifically looking for a method that allows:
I’ve contacted several professionals, but unfortunately haven’t received a clear reference yet. This methodology seems to be less known nowadays, so I’m hoping someone here — maybe with experience in older design techniques or academic knowledge — could share:
I would be extremely grateful for any help or direction you can offer.
Thank you in advance for your time and support!
Best regards,
- Calculating all the main geometric dimensions of the impeller (inlet/outlet diameters, blade angles, widths, etc.) based on known operating conditions (Q, H, N, etc.)
- Drawing the traditional cross-section step-by-step based on those calculated dimensions
- Designing the blades using the "method of arcs" or any classical graphical construction technique
- A reference (book, article, thesis…)
- Example designs
- Personal experience or guidance
Best regards,
