Loft: circular to square hollow cylinder
  • Thread starter Thread starter jeremyn
  • Start date Start date
J
jeremyn
Guest
I have a circular hollow cylinder (tubing) that I want to loft to a square hollow cylinder. I don't know how to loft hollow bodies. I'd like the inside and outside surface of the loft to be the same shape. Can anyone provide me with some guidance?
yes you can make it.........
but u have to use surface loft.........
so creat two lofted surfaces using inside and outside closed loops of two sections....
(its because u can vary the thicknesses of two different tubes)
ok then close these surfaces and knit (check the make solid option)....
so it creats different body ........then combine these bodies..........
KK
