C
cesar4324
Guest
I am using parametric location callout symbols to indicate position of detail views located on a different page than the parent view. The issue I'm having is that the zone indicated by the "&pos_loc:view:" does not match the grid on my drawing. Our drawing format has a 6-by-8 grid defined by numbers 1-8 horizontally and letters A-F vertically. The sheet called out is correct, but the horizontal/vertical position is way off. Example: when calling out a detail from a view that is on Sheet 2, Zone 2B, the symbol shows Sheet 2, Zone 23D.
I would appreciate any help to fix this issue! Thanks.
