VAD
Geotechnical
- Feb 23, 2003
- 390
Much needed. Thanks for the invitation. I will start by posing a question that has implications on work that geotechnical engineers are involved with with but never seemed to have been well explained.
Do we truly understand the phenomenon of arching in buried structures and how it influences the loads transmitted to structures such as large culverts?. There is very little said about soil load transfer to buried structures without base slabs that rest on footings.
If one examines the AASHTO and Canadian codes one will note differences in the approach in determining the loads. Although many apply the forulae presented in these codes there is very little available to discuss the mechanisms of load transfer. in fact some use the loads providede by the manufacturers of these structures who seem to provide the structural aspect but leave the responsibility of the foundations to the geotechnical engineer. All concepts lead to Terzaghi's work on arching which is in his Theoretical Soil Mechanics text where he references work of his predecessors. Work by Martson and Spangler which can be understood is now often put aside by statements such as that this approach is not applicable today. No reason given in particular.
A particular case in mind is how do we treat a footing projecting outside of the line of the barrel of a multi-plate culvert structure. Do we account for the overburden pressure in the design of the footing as an additional load on the on the projected part as height x density or do we reduce this amount as a result of arching or do we neglect it completely. The AASHTO codes indicates this should be accounted for but no mention by the Canadian code. In fact in the Canadian code there is very little information regarding the design of footings below these structures. Comments, opinions would be welcome. Since we apparently are governed by Codes we should strive to ensure that what is said is clear and understandable.
![[cheers] [cheers] [cheers]](/data/assets/smilies/cheers.gif)
