little help on patterns
  • Thread starter Thread starter vikas02121
  • Start date Start date
V
vikas02121
Guest
hi,
i m a pro/e novice and i m mailing for the first time.
I have a problem in making a pattern.
Actually , i m trying to make a pattern(angular) of the cylinder on the top of a circular disc but till now i m unsuccessful.
but i created a pattern of hole on the disc successfully.
plz help me out of it
thanx
vikas
Dear Vikas02121
Please take a look on the Pro on line help site - look at pattern - all informations are averrible and easy to understand
It
i have just started to learn pro/e. also i am learning ansys and ideas software.please help me about BOM
Ok, I will send for u one file.
Read the help, Any kind of help.
and ... try-try-try.
OK, I make a file for you, I think will help you.
adicar01
After creating the feature to be patterned, use the copy command and rotate it with reference to the axis with which you want to pattern - independent option. Then delete the original. Now pattern this copied feature using the an angle value which was created when you copied.
Rajesh S
Rajesh S
Use the make-datum option to establish your pattern dimension (even if it's zero).
Word to the wise, never put your pattern dimension into your sketch....
