lifting feature onto sketch
  • Thread starter Thread starter FHeckro
  • Start date Start date
F
FHeckro
Guest
Is there a command, which will allow me to create a drawing by lifting a feature from an existing part; Solid Works equivalent of
I tend to use dumb or non linked solid or surface features to create additional geometry
just copy any or all entities into a new part file and paste with no link
the little red lightning bolt on the design tree tells you that your geometry
is not linked
hope that helps
go to gsd & select the command "Extract",select that feature line & ok.Now u can c that line as a different entity now u can trim As u required.
