Hi, I've read through some of the existing threads for lifting but don't see anything that I think applies to my situation.
I've been asked by a client to provide a lifting certification (he thinks that's what they need) for a small steel framed structure that houses a bunch of electrical equipment. The structure itself was not designed by an engineer and has tabs welded to the top of it to hook the crane to and has been lifted via these tabs in the past. The client says they are looking for whatever they need to make the crane operators comfortable to lift this thing.
My questions are:
1) Since the frame itself wasn't designed by an engineer, should I check all the members and connections of it? (fun twist, the framing is actually totally covered in and no longer visible. All we have is a hand sketch showing the framing sizes and overall dimensions)
2) I think that to achieve a full lifting certification the lifting components between the crane hook and the tabs welded to the structure need to be certified. Is that true? If that is the case then I will recommend that to the client but it would not be in our scope.
3) Do the tabs welded to the structure need to be load tested? I'm unclear on that requirement.
I imagine that my task will be to check the tabs and welds to the structure for the various failure modes and the deliverable will be a stamped letter stating that the welded tabs are able to support the full load of the structure with the required factor of safety. Is that what others would do?
Thanks for any guidance!
My questions are:
