Library fail at assembly start-up
  • Thread starter Thread starter quadamage76
  • Start date Start date
Q
quadamage76
Guest
Hi everyone, I'm using Creo Elements Pro 5.0 M140 on windows 7 64 bits, if I realize an assembly using some library parts, for example bearings, when I reboot my pc and Creo if I try to open the assembly Creo is not able to find those library elements even if the library apperas in the lateral box (common folders). Can you help me to understand why?
Thanks Matteo
Does pro_library_dir option in config.pro show the correct path to the physical library?
of course, infact I see all my libraries in the left box (common folders).I forgot to add this information: I have many rows, in config.pro, like this one:
search_path ...(library path)\Librerie\Cuscinetti_supporti\Sfere
what, sometimes, I'm not able to find is some bearings contained in some subfolders of the previous path. The strange think is that, after the first reboot, now pro-e is able to find them. I don't know why sometimes he's able to find them and sometimes not...
Edited by: quadamage76
Found: I put more searchpaths including ALL subfolders.
