Jul 18, 2019 #1 JMRspain Mechanical Joined Jul 18, 2019 Messages 2 Location ES Hello, Does anyone one know by any chance a code that helps with the design of a leak sealing system on pipes or valves?
Jul 18, 2019 1 #2 LittleInch Petroleum Joined Mar 27, 2013 Messages 23,012 Location GB ASME PCC-2 Remember - More details = better answers Also: If you get a response it's polite to respond to it. Upvote 0 Downvote
Jul 18, 2019 Thread starter #3 JMRspain Mechanical Joined Jul 18, 2019 Messages 2 Location ES Thank you so much LittleInch Upvote 0 Downvote
Jul 24, 2019 #4 vanasia Industrial Joined Jul 19, 2019 Messages 1 Location VN Hello. You should have more detailed questions, because each type of sealing is used for a different purpose. What valve are you using, what fluid. I will answer you in a better way. Upvote 0 Downvote
