layers
zennis
63
Is there a way to transfer which layers that are on/off, froze, etc. in one dwg with many xrefs into another dwg? i.e. use the same on/off, frozen layers to be the same in each dwg.
I believe if you have the express tools, a command named LMAN will allow you to save and retrieve layer states.
"Everybody is ignorant, only on different subjects." — Will Rogers
Hi zennis,
which AC are You running? I think there are a lot of ways!
Do You have the Express Tools1-9?
* I use the command "_lman" (export-> import)
* or save as a *.dwt, You woll save the layer-settings too
Lothar
ADT 2004
ACAD 2002
Thank you borgunit and exxit, LMAN is what I was looking for. Again thanks.
zennis
