AaronMcD
- Aug 20, 2010
- 273
I'm not concerned with building code, this is just a personal project.
I am wanting to mount a heavy duty drawer slide into a cabinet with 1/2" plywood sides. One side is exposed so I'd rather not penetrate through the plywood. Since this is a heavy duty slide, intended to support a slide out fridge in a campervan, I want to run calcs to be sure it's not gonna break. The holes in the slides are for #10 and 1/4" screws. I found 1/2" long #10 and #14 screws at Ace Hardware.
Neglecting the 6D minimum, I'm coming up with Mode II failure at 75 lbs for the #10 screws. Due to the thin slide metal I don't think Mode II would happen. I imagine it would be more like Mode III but with pull out instead of screw bending. I'm getting about 90 lbs for a sum of pull out and main member corner bearing failure, but I imagine it would be less. I suppose I could screw into some scrap, stand on the slide and try and pull it out.
