Lateral stiffness of a helical spring 1
Omar_Whiz
1
thread404-162279
The above thread discusses the issue of finding a helical spring's lateral stiffness.
I have come across this issue myself, and desperately needed a solution.
Now, this is normally a non-standard way of loading a helical spring. Nonetheless, A.M. Wahl in his 1963 book "Mechanical springs" gives an expression for this.
Let us take β to be the spring's flexural rigidity, and γ to be the shearing rigidity. These expressions are given as:
β = (lo.E.G.d^4)/(32.n.r.(2G+E))
γ = (lo.E.d^4)/(64.n.r^3)
where;
lo = spring's free length
E = modulus of elasticity
G = modulus of rigidity
d = wire/coil diameter
n = number of active coils
r = mean coil radius, also equal to the outer diameter minus the wire/coil diameter
Now, Wahl states that the deflection due to a lateral force Q is given as:
δ = (Q.lo^3)/(3.β) + (Q.lo)/γ
And this is due to 1) bending effects, and 2) shearing effects.
If we rearrange the above expression and extract the lateral stiffness, we obtain:
k_lat = (3.β.γ)/((γ.lo^3) + (3.β.lo))
And that is the expression for the lateral stiffness of helical spring.
Extra note: The lateral deflection of the helical spring is effected by axial loads as well. If we have an axial load P, we can find a certain factor C1 which is equal to: C1 = 1/(1 - (P/Pcr)); where Pcr is the critical buckling load of the spring. If the ratio P/Pcr is ≈ 0, then the axial load has no effect on the total lateral deflection, otherwise the total lateral deflection can be found as:
δtot = C1.[(Q.lo^3)/(3.β) + (Q.lo)/γ]
Hope this helps!
P.S. Please check Wahl's 1963 book on "Mechanical springs" as it is the source of inspiration.
Welcome to Eng-Tips, Omar. Your first post and you seem to be well on your way to being a valuable contributor to these forums.
People commonly use coil springs loaded to bow or buckle (ever use an old IBM keyboard?).
It is good to see the actual calculation of the values.
