Large offset opening in blind flange with weldolet for reinforcement 2
boofi
Good morning y'all.
I have searched through this site and read some good information on tapping holes or nozzles in blind flanges.
Due to space requirements, we need to reduce from 16" to 10" within a 12" span. Originally, I was going to use a 16" blind flange, a 16x10 weldolet (flat), a length of 10" pipe, and a 10" flange. My question is, with the weldolet acting as reinforcement, do I still need to do thickness calcs for the (formerly) blind flange per UG-34? My gut feeling says yes, because the offset hole automatically means this is no longer a 16.5 component but a Section VIII component. I am fairly certain the 16" CL150 blind flange will fail on these calcs. Will I have to get a thicker flange then, regardless of the reinforcement provided?
Yes
Okay. Thanks! Too bad my calcuation software is corrupted lol.
Followup: There was a very long discussion here:
We use "bleeder blinds", or 16.5 flanges with a tapped hole on the face, nipple, and valve, all over our plant to make sure lines are clear before working on them. See below for example. The discussion above seems to indicate that any size 16.5 blind with a hole cut into it off center would require calculations. Does this mean all of our bleeder blinds need to be evaluated? It's unfortunate that the ASME committee didn't give provisions in their interpretation for something as convenient as a bleeder blind. Practically, we have never had an issue with these.
There's been lengthy discussion in the past on using weldolets for anything other than (a fitting on) piping. Simply put, dont use it for anything other than piping systems. Especially not something flat like a blind flange. Olets are designed for piping, not vessels or flanges.
Do you leave them on during process? Then they become part of your precess (requirements) and cant be seen as temporary testing devices.
That's incorrect. Read the thread (371342) again, Im sure it will be in there, but if the hole falls within the limits of table 6 of B16.5, youre OK without any calculation. Be aware table 6 onl;y applies to centered holes - if the hole is eccentric, a calculation will formally always be required.
From a B31.3 point of view (which relates to new construction), yes. Since you're the owner/user, Im not sure if that provides you with other/additional options to waiver certain B31.3 requirements?
There's a section in 304.7.2 that may provide a waiver for that.
Huub
- You never get what you expect, you only get what you inspect.
If you get a full hub blind flange you can put any size hole in it. It's still be a B16.5 flange so no calculations required. (not 100% sure about the hole offset)
I could only access that Interpretation by searching through the 'Check the status of your Pending Interpretation'-field.
Is this Interpretation already actually published?
Huub
Thanks. This is an interesting Interp. which I’ll gladly use in the future.
Huub
