Landing gear assembly
  • Thread starter Thread starter jbelle7435
  • Start date Start date
J
jbelle7435
Guest
I have been given a project to create a landing gear. I have created all the parts and made the assembly. My problem is how to place the pins at these three given ground points so when I do a dynamic analysis those three points will not move with the rest of the object. The sheet given just has three points called PNT0.
PNT0-- (-9.6)----
PNT0 | (29.379)
|(7.614)
------------------(-27.145)-------------------------------PN T0
best way to describe it...Anyone can help thanks!
you have an e mail adres ?
a have something but a i think must modify
could handle with if you have the solid models?
I can send- you some
Cheers
Cristel
I figured out how to make datum points. now when I assembly I have major trouble aligning my parts to these points.
I made a seperate part of 3 datum points. Went into assembly mode and loaded points file. Now I load a part to align with the points and I can not figure out how to easily.
